M
Mowgli82
Been asked to plumb in a washer into an external garage (not connected to house) - the location of the external building is about 6 ft away from the house so obviously considering burying the supply (to min 750mm) - but the garage has been built onto an existing concrete base and no idea what the depth is so wondering what best way is to not only provide the feed but to also take away waste water?
Is it feasible to come out from main supply, thorugh external wall, down into the ground to required depth, acrosss to garage, up on the outside wall of garage, through garage wall and into WM? bearing in mind obviously need for insulation etc. I cant find anything in WRAS to specify I cannot do this, or do I have to break the concrete floor and come up directly inside at a min of 750mm?
Also - nearest drain is about 8-10ft from where WM likely to be situated - am I best looking to tie into drain under ground level to ensure enough drop for the waste pipe run?
Must be honest - started to get sidetracked into a minefield of trace heating etc. and looked at the groundbreaker as a solution but just at a bit of a loss to find what is most cost effective and simple solution to the problem!
