No cold water from bath mixer tap
View the thread, titled "No cold water from bath mixer tap" which is posted in Bathroom Advice on UK Plumbers Forums.
R
RyanStan
Hi there,
So, as the subject says, I have no water coming from my cold water mixer tap (bath).
Cold water in the basin works fine, flush on the WC works fine, hot water on both bath and basin work fine - Simply the cold water tap does nothing when I turn it on.
I have just purchased and fitted new taps, thinking it was something wrong with the mixer. Still no cold water.
When changing the taps, the flex-hose is full of cold water, so I know there is water going up to the tap, but nothing comes out when I turn it on...
I have tried the air pressure trick by holding a sponge, cloth over the tap, turning on the cold, then the hot, then turning off the hot and releasing the sponge/cloth - still no cold water
Any suggestions would be appreciated.
Thanks,
did you have to wait long for the bath tap to stop running?
Well, I've never seen the cold water tap running (on the bath), but the bathroom sink tap doesn't even get a chance to start running when I close off the value, the kitchen tap runs for about 8 seconds and thats the lot
no when you turned the main stop tape off did you drain down through the bath tap?
can you get a flow of water through the flexi pipe when the tap is removed?
welcome along.
Ok...
Just done this:
I turn off the mains valve (under the sink)
Let the water run dry
Removed the cold water flex hose in the bathroom and put it into a bucket
Turned on the mains value
Water coming out of the kitchen tap, water coming out of the bathroom tap (basin), but nothing at all coming out of the cold water hose (bath) - Not even a drip...
Ok...
Just done this:
theres a valve turned off, pipework not connected, or if you have one a cwsc empty
has the flexi got a tap slot on it? is it open?
do you have a hot water cylinder? and do the hot taps work?
or is it a combi boiler and the bath cold was missed as being tank fed when the combi was fitted??
have a look in your loft to see if theres a tank bigger than 2x2x2 FT
I'll have to do that tomorrow mate, kids asleep n all that jazz!
If there is one, which it sounds like there is - I'm guessing its empty? Is this something I can just fill up? I had a rad blow out a few months back and the whole system was drained via a bottom value of a rad, could this be related?
No tap slot on the flex, just runs straight into a pipe that disappears into spider webs.......
I do have a combi that was fitted at the same time I had the rad blow out - Before that I had a big bum tank in my airing cupboard - Excuse the lack of plumbing terminology
thats fine and if you have a combi fitted they prob have forgot to connect up the tank out to cold water mains
One final comment - I've just had a look at the combi and there is a on/off valve (which is currently off) on one of the pipes - If I turn it, I hear water rushing through the pipe - What is this for? And why would it be turned off? Thanks
****EDIT****
Nevermind, after some googling, looks like its a top-up valve
Reply to the thread, titled "No cold water from bath mixer tap" which is posted in Bathroom Advice on Plumbers Forums.
RyanStan,
SimonG,
