Jun 8, 2019
12
DIY or Homeowner
Prepare for a long story/process....
Open vented system no longer heats downstairs radiators.
No thermastatic valves just manual.
Boiler downstairs, BAXI, seems to work fine
I am a DIYer, Homeowner just over 1 year.
Moved in, heating was fine.
Then some blew up in the airing cupboard.
After 8 homeserver visits and a compensation cheque for their lack of skills..
The motor has been replaced twice
The diverter valve 3 times
HW tank stat twice
Room thermastat once
Whole system drained twice.
Eventually the electrical problem was fixed
Since then, we no longer get heating downstairs, their last visit "there must be a blockage caused by sludge". This is when i sacked them off and looked into this myself.
I've removed and flush out EVERY radiator in the house (Yes, they did have a fair amount of sludge in, now removed) I placed them back in and bled the air. Still no heat downstairs.
So i drained the system down as much as i could, every radiator open, doing this, i found that even though the water stopped coming out, if i went to another downstairs radiator, it was full of water?? This may be normal, or this might be part of the issue?
This is when i also added a Magiclean filter to the system, on the pipe between outlet of the pump and diverter valve. I bought 2m of pipe and ended up with 1.3m left, only used around 30cm but there was a lot of trial and error with fitting due to very tight space. This thing is working a treat, up to now it has cleaned a good amount (nothing compared to what i manually flushed out, it would have taken months of cleaning for the filter to do the same job if at all)
Once drained, i cleaned the header tank, added 2 liters of 800x cleaning solution (I have 9 radiators, most single but some double) so this should have been more than enough. Let everything fill up and bled the air, ran for 24 hours, mostly with heat, but at night i turned off the boiler and left pump running.
Next day i went around to each radiator at a time, attached hose to downstairs radiator, left the top tank filling ON, and left the pump on.
My idea was to keep adding fresh water to the system whilst draining each downstairs radiator, diluting the chemical in the system (Not letting the header tank get low) did this for around 2 hours.
Then drained the whole system. again, downstairs radiators still had water in them? so drained them manually as well.
Added neutralister to the header tank, let everything fill up, bled and ran for 1 week.
Still no heat downstairs!🙁
So i learned about air locks.
Upstairs rads were fine and bled, so turned them all off at just 1 side as normal.
One at a time, isolated each radiator, bled out pressue, removed whole bleed nut(i think its called) attached a plastic nut to hose adapter.
Then i opened one side of the radiator fully for a few seconds, from what i can tell, a few bubles came out, turned that side off, did the other side.
Moved on to the next rad.
Every time i did this, hot water came through one side as expected, so the hot feed must be fine.
The cold side also generated high pressure as expected.
So this is where i am up to.
All upstairs radiators turned off, no heat downstairs.
Hot and cold feed seem to be fine to me.
pump seems to be working fine.
I have no idea what to do, the hot water is being pushed into the radiators, the cold water will flow backwards at force, so i assume the pipe isn't blocked.
Any ideas or questions extremely appriciated 🙂
ok Snc...can you put up a diagram of your system as you reckon it is...just biro one will do...include the boiler, the pump etc and any 3 way valves etc. crucially are the defuct rads
on the main system or is upstairs on a diff loop than that below or are the dstairs all dropped. centralheatking
Had the same situation on a job recently found a big blockage on the flow from the boiler into the pump get a magnet a try the circs in the airing cupboard to see if it sticks
  • Creative
Reactions: Damselfly
Do you have a separate thermostat for the heating downstairs, the system may be zoned with another 2 port valve somewhere. If so, you would have two room thermostats.
Or perhaps there's a gate valve on the return from the downstairs heating system somewhere. How old is the house? Could also be an old non return valve on some pipe work somewhere thats blocked or stuck shut.
This is the heating plan as far as i am aware.
All upstairs rads off - 2 rads downstairs kinda warm, 3 main ones stone cold.
I am sure the pump is working, as i've opened drain valves on lower rads with and without the pump on and i'm confident it is producing pressure when on.
@Steve weightman before all the cleaning, a magnet would stick to the water/air seperator in the aircupboard, i've just tested and it still does
@Jones82 It's only one zone for the whole house
House built in 1997 so not that old!
Like i said, i can isolate a rad downstairs, take out the nut from the top, put on a house and open each valve on the rad, one will give me flow hot water, other will give me flowing colder water, so the pipes going to them seem fine....
If there was for some reason a non return valve on the heating system, where would i look?
The place I found a blockage was on the pump isolation valve and an amount of pipe just before it . I found all rads downstairs weren't working and also cleaned all the rads with system cleaner
Id still be looking at pump or a partial blockage, heat rises.
I think you would benefit from a visit from a recommended engineer.
Do you have any recourse with homeserve ie you’ve paid and they’ve not delivered.
Id still be looking at pump or a partial blockage, heat rises. You may get “pressure” as you put it but you’ll also be getting head of pressure from the tanks in the loft
Reactions: Rob Foster
tbh that sounds about right, with the amount i've done and checked.
Luckily heating is covered through TSB home insurance, if the heating breaks, they come out for free. Unfortunatly, it is homeserver TSB use for these call outs. So i've lost 4 full days as holidays, could be worse, but it shouldn't have taken 7 visits to diagnose an electrical issue with the room thermistat.
Are you closing the bypass when you're turn the rads off upstairs also?
Otherwise it'll just sail round the bypass if downstairs are air locked.
Edit: Sorry from the diagram I assumed there was one, but there isn't from what I can see on pictures.
HW tank stat twice
I want to take you back to...
'something blew in the cupboard' then you called homeserve..up till then your ch was operating ok ? but they did not fix it...yes. The liability really lies with them who knows what their numpty has done...centralheatking
Reactions: Shcuble
No i'm not, did know about this.
i'm not sure where this would be, i'll take a few pics as i've only got 3 gates to choose from
Sorry I edited my post after that. I thought from the technical diagram you had a bypass but from the images it doesn't seem you did.
When closing the upstairs rads, do you also close the gate valve on the return from the cylinder too? (I'm assuming you've also got just the heating on, not HW also). Also what speed is the pump set on.
Also the way it’s piped up, the cylinder coil can’t vent of air. I’d be inclined to remove that compression elbow with a tee and on a vertical piece of pipe, install a auto air vent
  • Agree
Reactions: EvilDrPorkChop
