View the thread, titled "No hot water. 3 ladies in the house. I'm feeling the heat (but not from the water)" which is posted in Bathroom Advice on UK Plumbers Forums.
Here's the problem:
  • Central heating (wet underfloor) is fine.
  • Hot water comes out of any tap/shower for 60 seconds, then cold.
  • This happened suddenly, was working fine before that.
  • Boiler working OK.
  • Pipes within a couple of metres of unvented cylinder are hot.
  • Pressure gauge to cylinder is broken (so can't read input pressure)
  • Supplied by water main, good pressure in house generally.
My Theory:
  • Water is hot in the cylinder and therefore heats up water in the pipes gradually.
  • Whet tap turned, hot water in pipe comes through. This quickly runs off and only cold water follows.
  • So, the hot water in the tank is not being pushed through the pipes, it just stays in the tank.
Is that a good theory? And if so, what would cause this? Tried turning of mains input to cylinder, opened hot tsp til it stopped, twisted the tun dish for a bit, refilled and the closed the hot tap. Didn't fix it. I am thinking do I need to drain the cylinder completely via the drain valve at the bottom, then refill? Also, could it be the silver automatic valve causing the problem? I actually have two cylinders side by side so hard to see how both ports would fail at the same time?
Any help? The ladies will be home soon 🙁
you have 2 cylinders i cant see both 2 port valves failing so possibly not calling for heat check your clock. if calling for hot water check the small lever on the 2 posts on the cylinder the valve with the silver box it has a lever on the side if open (lever loose) then its open if its stiff and yoiu need to push it then its broke but you have immersion heaters on each cylinder two electric switches under the big red vessel. these should see you ok till you can get someone in
I see you have a secondary pump yellow bronze thing in pic. I assume this is a large house. So check controls are set to hot water on, check both zone vales feeding the tanks are open (little lever at the side indicates this), put your hand on the bronze pump to see if it is warm, run the hot tap and check with your hand the water is leaving the cylinder, leave the hot tap on a long time to see if eventually it comes through at the tap. If you have good pressure at the hot tap, its going to be an issue with controls, valves and secondary pump, assuming boiler is functioning normally for CH.
cheers
If it’s been fine until now, it’s probably a shower mixer cold crossing into ththe hot.
Looking at the install there’s no balanced cold connection.
The yellow pump was apparently put in to help hot water get to the loft room. The guy who owned the house said he only turned this on in the winter. In fact we've never needed to use it. The timer for is powered, but set to off and always has been so don't think this is a factor.
Ran kitchen hot tap, warm then in 10 seconds cool. Tested for 2 mins, stayed cool. Water in both cylinders at 65 degrees and hot to touch (tested by opening into tundish and feeling - now have sore finger!)
Could be drawing back up the secondary return .
Try turning both of the blue valves connected to the pump/cylinder.
Those should have non return valves fitted to stop that.
Running hot tap. Started very not for 5 seconds, then cool for 30 seconds, now cold after 1 minute and still cold after 10 minutes.
Re the blue valves, which ones (see pic) and what do these normally do, is it ok to leave them turned off?
One more clue, when I turn off the cold water main where it enters the house, the hot tap in the kitchen drops pressure by about 60%, turn the main back on and starts running but is colder.
So I think the basic question is what can stop the hot water getting from the tank to the taps?
Turn 1 and 3 off for ch suggestion
Can you turn the red ones off as well at the top of the cylinders then open a hot tap does it stop ?
Ok, will do in a minute.
On the two port Honeywell valves, both levers are loose when timer calls for heat. When timer in off position, lever doesn't move, but can be manually pushed from auto to open, but you can feel the mechanical resistance when doing so, so I think these are working fine.
We do have a bath thermostatic mixer that seems to be faulty, could be the problem? I'll need to get someone in, could you explain how you'd go about testing to find the problem - we've got 7 mixer taps and 4 showers in the house!
Yes can you isolate that ?
That's the fun part
In short isolation each until you find the problem one
So when the Lever is closed it can back fill because the hot and cold meet and mix before the lever closing.
In effect they are then in one pipe, and the one with the stronger pressure can push the other back down the pipe, or hold it at bay, stopping the hot having any flow to outlets.
This should not happen because a NRV acts as a barrier to stop back flow. If an NRV has failed it would allow the ba flow and this could be our problem?
We would need to isolate each mixer, and then turn on, one by one, to see when the problem returns.
Is that right?
It couldn't be an airlock in the pipes instead could it?
Correct the nrv stops the back flow
Can happen depending on your mains water pressure eg higher than your hot
No you wouldn't get any water then
Reply to the thread, titled "No hot water. 3 ladies in the house. I'm feeling the heat (but not from the water)" which is posted in Bathroom Advice on Plumbers Forums.
Thread starter
Joined
DIY or Homeowner
Thread Information
Title
Prefix
N/A
Forum
Bathroom Advice
Start date
Last reply date
Unsolved
Mike Jones Amber Hill,
Ben-gee,
