K
Kelly W
I woke up this morning to the boiler not working as the pressure had dropped to 0.4, I’ve managed to re pressurise that now and it’s sitting at 1.2 and the heating came back on so all good, that was until I went to jump in the shower and realised there is no running hot water, I’ve checked all the hot taps in the house but nothing, I turned the boiler of and in to see if it would make any difference but again nothing. Can anyone help?
I would check the motorised valve on the hot water side, if it's not opening you can open it manually by pulling the little lever on the side and locking it into the notch. Hope this helps
