View the thread, titled "No hot water from Tribune Premier tank." which is posted in Bathroom Advice on UK Plumbers Forums.
Simon.h
Hi all,
I have very little hot water pressure from my Tribune Premier unvented hot water cylinder, i have checked the Pressure regulater/strainer and they fine. Its 15 years old and was fitted by the house builder.
Any ideas
Cheers
Simon.
If the pressure reducing valve & strainer are ok then it sounds like cylinder is scaled up.
Over time scale collects in the bottom of the cylinder and blocks the cw inlet.
Usually when you open a hot tap you get an initial burst of water that reduces quite quickly to just a dribble sometimes.
Quite common round here (north hants) & mainly on direct unvented cylinders.
Well had B.Gas out to fit the boiler again (not lighting), i said to the bloke can you have a look at the hot water as ive got no pressure, he said its your strainer its blocked, i said i checked it and its fine and ive got good cold pressure on the 1st floor, i then said is it my cylinder scaled up? 'No cant be its stainless steel' i said its not its steel ive got all the paperwork for it 'well ive got no idea' and he left!
What a waste of time he was!
Does anyone know any good companys all the Reading area?
Reply to the thread, titled "No hot water from Tribune Premier tank." which is posted in Bathroom Advice on Plumbers Forums.
