No hot water on intesa (ariaton) combi boiler
View the thread, titled "No hot water on intesa (ariaton) combi boiler" which is posted in Boiler Advice Forum on UK Plumbers Forums.
00gadge
Hi I'm after some advise please. I've changed a acuator and gubbins on a diverter valve on a intesa (ariston) boiler. It has worked for 24 hours but now no hot water.It fires ok on htg. I'm thinking dhw thermistor but am really after a second opinion or correcting please. Many thanks.
I think you need to have a qualified person look at this before you throw any more needles parts at it.
hi the water is not hot, boiler not firing on hot water.
If the boiler does not even attempt to fire it is more likely the flow switch rather a temperature sensor. Do you get a flow rate nearby the specified rate?
Hi yea the flow rate is fine. I'm a engineer but mainly on installs not done many repairs/fault finding.
I've tried the flow switch but still no joy. Any ideas anyone it would be much appreciated.
Has this boiler been repaired mate.. if so I'd be grateful for the feedback...got a similar problem
Reply to the thread, titled "No hot water on intesa (ariaton) combi boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
00gadge,
RoryD,
