J
jacter
Hi We recently had a new stainless steel cylinder installed after which we had very hot water even though the thermostat wasn't up too high. This morning however we discovered we had no hot water or heating. Can you tell me if you think this may be due to the new cylinder? I've checked the pilot light and that's coming on fine
The fact that you mentioned that the water was VERY hot probably means the control thermostat was set too high and this will have caused the high limit to trip.
what make is it?
Is the high limit stat part of the immersion heater? If so there's instructions on the cylinder as to how to reset it
There will likely be only one. It will cut off the immersion amd the source of heating. Take the s,all cover off ( should unscrew ) then press the reset. If this works make sure the control stat is turned down a bit.
