View the thread, titled "No hot water to bathroom" which is posted in Bathroom Advice on UK Plumbers Forums.
H
harkai
Any ideas! I have a Vokera compact 29 hot water to kitchen keeps running hot and cold, to bathroom when running bath not even lukewarm had thermister changed and water pressure checked noticed when water starts to run cold green light starts flashing on front of boiler its only 3years old any suggestions?
The cheaper option is to install a Combi mate, they use siliphos crystals to reduce the build up of limescale... the best option would be to install a water softer but thesea are expensive... the bore in the secondary heat exchanger is very small and easily blocked up like this.. see what other advice you get off this forum but i would go with a new heat exchanger and a combi mate....
Reply to the thread, titled "No hot water to bathroom" which is posted in Bathroom Advice on Plumbers Forums.
