View the thread, titled "no hot water" which is posted in Bathroom Advice on UK Plumbers Forums.
sox
just fitted a shower pump to the expance pip of cylinder but now there is no hot water to the rest of the house. the hot water runs for about 4mins & the pressure is low
put new gate valve on the cold feed from the cistern to the cylinder & feed cold water trough the hot water pips back to the cylinder for the air lock, still no joy
Perhaps the pump is using off the water off the hot supply and pulling air down the expansion pipe?
Did you branch into the expansion pipe or fit a bos on to the top of the cylinder for the pump.
Have a look at the Essex flange site.
Is it only a problem with the pump running?
Check supply pipe from DHW tank - is the gate valve fully open? Is it all in min 22mm pipe?
Reconnect to cylinder with Essex flange
As Bernie has already pointed out, if your pump is on the vent pipe (expansion) it is in the wrong place . It will pull the column of water down the pipe and will then let air in which it sounds like is giving an air lock, rather than pulling hot from the cylinder . Pump needs alternative feed I would guess
thanks for all the tips on the hot water but the problem was a gate valve on the cistern was stuck closed. but now have anther problem can seem to get hot &cold water thrugh the pump to the shower. pump is not connected to the main supply
have aread of the instructions sounds like this pump was connected up correctly in the first place and they dont like being run dry either, screws them up somewhat
Try connecting it up first.
Have you got the correct type of pump? (if the shower is above the tank height then you need a negative head pump)
Try it with the pump connected before you alter anything.
Is the pump positioned correctly (i.e. level or near to level with the bottom of the cylinder)? Have you used 22mm pipework for your shower pump feed and supply runs for both hot and cold? (not critical for low volume pumps (eg 1.5 bar) but if you have higher pressure pumps (2.5 bar plus) it is important)
how can you tell if your pump is pull air from your expance pipe & if i turn off the gate valve at the tank to the cylinder & drain off the radiator at the lowist point would it then be possible to change a radiator
Are you saying you have a primatic or direct cylinder (as opposed to indirect)?
An indirect cylinder has a separate coil inside through which the primary circuit runs, keeping the heating water separate from the domestic hot water.
i don't no if it is a primatic or direct cylinder. also do you think it would be better to fit a surrey flange then have pump connected to the expance pipe.
If its still a problem, then yes. However I would suggest an Essex flange as the apreture is larger. Put it as high up the side of the cylinder as you can before the domed top.
If you are wanting to change a radiator, look in your loft and see if you have 2 tanks. The smaller is for the heating circuit. See other threads about the subject - already covered in depth.
there are three tank in the loft two large & one small tank
tested the pump, cold run ok but the hot run for about 5mins then stops could this be because i have fittered the pump 1/2 way down the expance pipe & not fittered a surrey flange
Sounds strange. Are the two large tanks connected together or do you have two separate systems?
if it were a problem with the expansion pipe I would have thought the problem would be from the start and not just afer 5 mins.
Have you checked you aren't running out of water in the tank in the loft when the hot stops?
I've also seen two tanks, with one connected to the other by a 22mm pipe in the bottom and the one without the water flowing into it full of slime and fungus.
Reply to the thread, titled "no hot water" which is posted in Bathroom Advice on Plumbers Forums.
