View the thread, titled "No hot water" which is posted in Bathroom Advice on UK Plumbers Forums.
T
tvman
Hi, I have no hot water on my Ferroli optimax HE31C boiler. ( I am a TV engineer by trade but have managed to repair my boilers in the past with the help of forums.).The heating works fine.
I suspect that the flow meter is causing the fault as if I put a meter across it there is no change or voltage drop when the water is flowing. I have also done resistive checks across it and there is no change when the water is run. I see from different entries on the forums that the diverta valve is suspect. Can anyone give me any advise, apart from the commom thred that runs through every thing I have read so far " Dont buy a ferroli boiler "
Many thanks TV MAN
could be the flow switch or relay on pcb sticking but as said usually the divertor valve sticking .back to the old cure first,give tham a tap see if they free off and arange replacement as required ,mind you,you will be replacing old parts for new substandard parts that will not last much longer
Reply to the thread, titled "No hot water" which is posted in Bathroom Advice on Plumbers Forums.
