PlumbersMate
Went to a flat earlier with no hot water. Checked the cable feeding the immersion and it has got power going to it, can the actual immersion still be broken? Even though power is going to it? I took the casing off it and temp is set to 65.
I am here: http://tapatalk.com/map.php?0wmngr
Check for continuity of thermostat (with power off).
Yes although power is available immersion or thermostat can break down.
Is there a reset on thermostat, little red button you need to use a pencil point to operate?
Is the stat set on Max, clamp meter will tell you if its pulling anything, multimeter will provide you with voltage reading at the elephant or tell you the resistance across the terminals.
