K
kevcrane
Hi everyone
turned hot water off at the cylinder to install a bath, now no hot water from tap. Any suggestions?
Many thanks
Yeh its defo air locked without a doubt , no youl just have to clear said airlock,, as long as there are no non returns on the hot you need to try n force cold water up the hot , simply by attatching a hose from bath tap to bath tap, or if your lucky enough to have a mixer tap in the house without non returns,
easy to snap a gate valve or its airlockedbest place to back fill is usually the kitchen sink or if you have a dual feed washing machine just link it there often find behing the washing machine even if its cold feed only theres a un used hot valve
