N
n.chapman
hi, we have a problem with our boiler noise, we moved to this house in may and we have had a new combi boiler fitted in the loft the exsisting one was in the kitchen and was a balance flu. the piping is microbore to the radiators, we had a new bathroom fitted at the same time. The garage has been converted to a study which is on 15ml we had the heating system power flushed out and had new rad valves fitted, apart from the one in the study. All the internall walls are stud partition. After the boiler has been running for an hour or so we get a drumming noise in the corner of the lounge which is the other side of the stairs with the boiler on the external wall inline above from where the noise is coming from, it sounds like a car engine running outside, if you slowly turn a hot tap slowly on and off you can make the noise go down and up. we are also on our third thermostatic shower valve as when in the shower the shower goes completly cold, this all since the end of august. our plumber seems to have given up
many thanks for reading this
