View the thread, titled "noisy non return valve." which is posted in UK Plumbers Forums on UK Plumbers Forums.
Dan Masey
I have a unvented system and have run a secondary return on the hot water due to the size of the property. I have a non return valve directly after the bronze pump that rattles and is causing a nuisance. Is there a diff type of double check valve i can use to stop this rattling?
I normally use this type.
But it must be installed in the horizontal or with the arrow pouting up.
Those check valves always rattle, the swing valve above will remedy it & prolong pump life probably
ive found sometimes that no returnes can be noisy when there the spring type and they've jumped out of place, try replacing the valve like for like first or as above use the swing valve
I've installed a double check valve. Have no idea if it's spring loaded or no? Maybe I'll try and like for like swap and see what happens. I've never heard of the swing valve before?
Wrong type mate Google swing valve and install one
Ok I'll pick one up tomorrow from pipe centre. Any reason why it has to be installed horizontal? My NRV currently points down after my pump then into my megaflo.
So the flap closes but some have a spring on them and there ok horizontal
I put it up as I wasn`t sure that there would be enough water there not doing gas boilers.
But the pressure of the unvented cylinder will surely close it? It's basically another hot water outlet on the cylinder. I thought the NRV was to protect the pump?
Will open one way but will shut if the water back flows
Think about it Dan what pressure is there at the other end of the return away from the pump?
So long as the hot & cold are all balanced & the pump is running when any hot water drawn, then I am not convinced that a non-return is required but the MI's alway show. It is installed to stop cold water from the feed being drawn back up the return to the taps missing out the cylinder as it were.
When no water is being drawn then both sides of the check are at the same pressure but flow from the pump will push the gate open so water can circulate around the closed circuit.
Reply to the thread, titled "noisy non return valve." which is posted in UK Plumbers Forums on Plumbers Forums.
