A
andy_s
I have an open vented y plan central heating system, the pump is located in the first floor airing cupboard. Boiler is a concord WRS 240A in the ground floor kitchen. Initial problem, the hot water was not as hot as it usually was. I traced the fault to a reduced flow out of the indirect heating coil, the pipe was very nearly blocked and very magnetic. The feed from header tank was tee’d into the outlet of the coil! I have replaced the section of blocked pipe and re-routed the 15mm cold water feed into the 22mm vent, which is about 150mm from the inlet of the pump.
The system has always been noisy when on water only, I guess the air passing through has contributed to the original pipe blocking up. Having replaced the pipe I’d like to address the cause of the noisy hot water circuit. I can bleed all the air out with the pump running and the gas off so that the system is quiet and cool, but about 10 minutes after the boiler fires up I get the familiar swoosh through the pump in the airing cupboard. I have system cleaner circulating at the moment and would like to get a result before I flush out and re-fill with the inhibitor. The vent rises up above the FE tank before bending back down and I haven’t seen any sign of pumping over. All ideas gratefully received. Thanks in anticipation, Andy.
