Non return valve on unvented
View the thread, titled "Non return valve on unvented" which is posted in UK Plumbers Forums on UK Plumbers Forums.
gingalig
Hi, thanks in advance for any advice, I've come to change a manifold for the ufh, I have noticed a non return valve on the main dhw outlet on the unvented cylinder
Is this acceptable ?
[automerge]1570704464[/automerge]
My thoughts are no it's not.
There's no safety reason why it shouldn't be there and is no different to having non-return valves anywhere else on the hot distribution side of the system. Do you have a secondary return (pumped circuit) on your system?
No there isn't. Thanks for the reply.
Unless you can find a decent explanation for why it's there I don't think it's necessary but at the same time it's not really doing any harm either.
It would be interesting to know the reasoning behind it being fitted there though.
So they went for a "whole system" approach rather than at point of use I suppose. The shower feeds may have been inaccessible which would make sense of that valve's position.
And at least it's easilly found and accessible if it fails.
Probably a tmv/ mixing valve causing an issue. Is your cold water alot better than your hot? Pressure wise?
Many tmv's have problems if theres a different between the hot and cold.
Reply to the thread, titled "Non return valve on unvented" which is posted in UK Plumbers Forums on Plumbers Forums.
gingalig,
AWheating,
