Bibilapetite
Hello
i need to replace a leaking tap on an old bath. The inlet centres are 160mm apart and I'm struggling to find a suitable mixer. Does anyone know of a supplier? I have tried eBay, Amazon, Plumbworld etc. Almost all seem to be standard 180mm and the distance isn't searchable on the sites which basically means clicking through on every single one and going into the data to check, if available.
Cost is a significant consideration and I don't really care what it looks like as long as it doesn't leak.
Thank you!
Bibi
hi welcome to the forums. i would think you need something with adjustable legs like this
18464.jpg83848.jpg you can fit the legs either way so that they lean in or out
If the above is a no go you could always use x2 single bath taps, does mean you lose the ability to have a shower hose on their though.
Thank you Steve B, the adjustable route seems to make most sense as it would be better to be able to attach a shower head to the mixer tap.
Can I buy any legs and any tap? Is any tap with legs automatically adjustable?
Thanks a lot!
Hi, I have the same prob. no mixer taps for my bidet (karat) wit 160 centres. The plumbing associations are no help they pass you on and direct you to where you can request a brochure, realy!!!! ivan
