Non-Standard pipe connection - please help!
View the thread, titled "Non-Standard pipe connection - please help!" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi, I have an opening on the 'manifold' (I think that's what its called) on my soil pipe. It appears to be a non-standard size - about 51mm internally.
I'm trying to connect a 40mm floplast solvent weld pipe, and can't find a boss adaptor that even nearly fits.
I can't cut a new hole above, because it would be too high. I can't go into the floor cavity without lifting two layers of marine ply that I've just put down - plus I think the manifold continues under there that I don't think a tee would fit on to.
Does anyone have a solution to this? Or even a bodge?
What the Damn is that fitting. Is that even air tight? it looks like the branch is just loose in the top of the boss pipe.
Check for a name or product number on the boss then try and find the right adaptor or shop around for a variety of sizes until you get lucky
Yeah, I dunno - it keeps the toilet waste separate from the bath/basin waste internally. It's all sealed and works fine tho yeah
It's just the opening - I've really searched online, but every boss adaptor I can find is around 67-68mm. Is there some other adaptor I would look for? Or a place that sells non-standard/to order parts?
Otherwise I was thinking of bodging it in by trimming a boss adaptor down with a stanley, and then using silicone.
Then maybe covering the whole thing using one of these -
Thoughts?
Reply to the thread, titled "Non-Standard pipe connection - please help!" which is posted in UK Plumbers Forums on Plumbers Forums.
tomcox,
snowhead,
