Guest viewing is limited
Not really plumbing but you all know your stuff! Gas Oven
View the thread, titled "Not really plumbing but you all know your stuff! Gas Oven" which is posted in Gas Engineers Forum on UK Plumbers Forums.
A
axil23
Like it says above, I don't really know who to consult but have always had success with this forum.
Got a built in eye level double gas oven from 20 years back which has finally given up. Need to replace it but the problem is that all new Gas built in ovens I am seeing are 60cm across. The space I have is 55cm. Could probably squeeze in a 57cm one if I chisel out some wood. But I can't find any smaller then a 60cm wide version.
Can anyone help suggest one?
They are 600mm to fit a standard base unit. You can get smaller and I had a cheapo Beko cooker in my spare flat which was about 550mm. Try Curries, Comet or any of the big electrical retailers, they'll be able to help you.
Tried all those + lots others. All seem to be the standard 60cm size.
Look for built in double ovens. Go to the manu's website and check the sizes. The 596mm or whatever size width is over the facia. Some built under ovens are 600 wide in behind and require the unit to be removed and the oven sits on rails. These types are not suitable.
Just look around.
The 595mm is the overall size across the facia, the part that covers the space. The oven itself is 547mm. They are all made to fit into a standard 600mm larder unit.
The 600mm size is the outside measurement. The inside size of a 600mm unit is 570mm - 556mm depending on the thickness of the carcas.
Unless you have a custom built unit, they will fit but check with the manufacturer.
The sizes for the Belling B190G are
Perfect. Will have a look now.
Fit like a Glove!! Thanks!
Reply to the thread, titled "Not really plumbing but you all know your stuff! Gas Oven" which is posted in Gas Engineers Forum on Plumbers Forums.
axil23,
axil23,
