View the thread, titled "novice diyer needs help re installed cold radiator" which is posted in DIY Plumbing Advice on UK Plumbers Forums.
J
jj1960
i would like to give as much info as i can so please bear with me
about 3 years ago i took out a radiator from the bathroom so that the other half could have a corner bath
i live in a bungalow - the radiator was fed from a pipe from the ceiling(15mm) i got a freeze kit cut the pipe and fitted an isolation valve
at the bottom of the rad was a myson trv this i left in place as it would be behind the bath
the other half was complaining a little about the cold in her wee studio at the side of the house( its just a shed really)
so i decided to fit this radiator - i managed to attach a 2ft pipe to the trv and fitted an isolating valve at the end of it and openend the trv(access to the trv is very difficult)
from thes two pipes in the bathroom i ran 15 mm plastic pipe to the shed and connected the rad ( i flushed the radiator before fitting )
i opened the isolating valves and the rad would not heat
next i traced the ceiling pipe into the attic (remember i live in a bungalow ) it went across the attic and down into the hot press where it is tapped at right angles into a 22mm pipe which is roasting when the heating is on
after much head scratching i decided that i would loosen the nut at the isolating valve just before the trv in the bathroom and see if the hot water would travel through my pipe work and the rad just incase there was an airlock or something
after a long while of letting the water drip into a tin and emptying it the hot water finally appeared i tightened the nut and went to my scratchcer
got up this morning put the heating on and the radiator is not getting hot the pipe coming down fom the ceiling in the bathroom is cold
that is as far as i have got now i am stuck and would really appreciate any and all help
thanks
you need to balance the other rads out via the lock shields to force water into the new rad. Sounds like you might have a job as Iso valves will be restricting the bore of the pipe even when open. Im confused by what youve done, any chance of a piccy?
Reply to the thread, titled "novice diyer needs help re installed cold radiator" which is posted in DIY Plumbing Advice on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
DIY Plumbing Advice
Start date
Last reply date
Unsolved
jj1960,
fuzzy,
