Guest viewing limit reached
Oil tank valve issue.
View the thread, titled "Oil tank valve issue." which is posted in Boiler Advice Forum on UK Plumbers Forums.
Hi I have an oil tank valve that needs replaced as it will not shut off fully.
I understand that probably the best way forward is to wait a few months till oil level low then raise valve end of tank but is there a way to bung the oil if say you encountered a leaking valve?
I was thinking many some kind of plug or plastic flap fashioned to a stick to seal inside outlet. 😃
Any thoughts really appreciate
Thank you.
Do it live, ensure you will catch any spilt oil, be quick lol.
Maybe Jet swet? Personally never used it, marketed for water.
Reply to the thread, titled "Oil tank valve issue." which is posted in Boiler Advice Forum on Plumbers Forums.
Stratf01,
Timmy D,
