buffy27
whats the craic.
has anyone ever cleaned out an oil tank?
i have not done this before.the oil is out of the tank ,but what i need to know is do i need a detergent or something in order to remove the sludge in the bottom of the tank and on the walls. can i just wash it out with water????
i understand that water and oil are not friends and can cause alot of hassle with the kerosene burner.kerosene having a relative density of around .82 and water obviously 1.[it floats and does not mix as a result]will i just rince it with water and try and let it dry as best i can???
thanks in advance...buffy.😀😀😀😀
