Old one pipe system
View the thread, titled "Old one pipe system" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Matt0029
Been to look at a job, somebody has bought houses wanted a radiator capping off and a radiator moving. System is on a combi. Is an old one pipe system though. With the pipe runs etc I have advised repiping to a 2 pipe system. Pipes come in upstairs then drop down. 3 rads downstairs 4 up. Downstairs radiators pipe work in void underfloor boards. Cutting back on these tees on 22mm and converting to a 2 pipe system. Well I have advised repiping to a 2 pipe system everyone else suggest that's the right call.
Check the boiler's MI's, they probably won't 'allow' a one-pipe system. Even if they do OPS were traditionally designed for 75 or 85°C operation (and no TRVs) so the boiler probably won't be able to work in condensing mode, which will add about 10 or 15% to the fuel consumption.
Now I'm not saying it's not possible to get a combi to drive a OPS and work satisfactorily, but expect it to take a lot of fiddling around (unless you have a lot of experience with the beasts, which is getting unusual these days) to get it balanced and working properly, which the customer probably won't want to you pay for.
Thanks it's a house someone has bought. With the stage there at now I have recommended changing/repiping to a 2 pipe system. It's on a combi a moment a 2 year old gloworm
It also looks like the pipes still go to the old back boiler. On the one pipe circuit even thought the system is on a combi.
It's like the flow and return, is a loop one pipe system is still flowing through the old not in use back boiler. The 15mm that drops down is the main loop for the one pipe circuit still
Probably best to start a fresh. I tend to agree with Chuck.
It will work but it is not compatible with a modern boiler.
I cant believe someone installed a combi but didnt change to 2 pipe there and then?! Sounds like a DIY job! How can you strive for efficiency on ANY system these days with such an arrangement?! Leaving the old back_boiler in circuit is also asking for trouble as that will end up with wasted heat from the system going up the back boilers' flue. If in doubt, put a bigger pump on the system after adding the extra pipes lads!
Yes they couldn't be bothered talking the old back boiler out pipes still go around that
I took one out this week which had been left in when the customers new boiler was installed years ago. This is partly why they manage to work cheap. Half a job!
I’m repiping a house next month. Combi boiler installed about 7 years ago on a one pipe system that had partially been converted to two. Now rads in parts of house have stopped working. It would appear to be a not a too uncommon bodge
Some folk do not understand the principles involved in a one pipe system. Alterations can easily upset them and prevent them from working. You need to understand some of the basic principles in plumbing which are no longer taught or experienced.
Exactly and whoever fittied it cutting corners. They just wacked the boiler in and moved on really.
Best thing to do is repipe whole thing. There are still the odd house I come across the a back boiler and I always recommend / and will only do a repipe as modern boilers don’t like one pipe.
If there was no option for the customer, you could use a plate or header of some sort but in the end it would be best to replace it with a two pipe, I agree.
In larger buildings it isn't always an option, e.g. old Church, School, Health care etc. You can still run a one pipe system well off that set up, although the inefficiency of the actual system remains, even though the boilers are performing a lot better.
Reply to the thread, titled "Old one pipe system" which is posted in UK Plumbers Forums on Plumbers Forums.
Matt0029,
Last Plumber,
