rocketmanbkk
4,106
903
113
Langley, Berkshire
Chap has an old (30 odd years) close coupled toilet in yellow!
He dropped something on it, cracked it, tried to bodge fix it but it is leaking.
I told him no chance to fix.
He now wants to replace with a modern toilet.
If the old toilet floor fixings are difficult to undo, as they look embedded, rusted and covered in some sort of silicone plastic type paste, would you crack around and remove toilet and then get some grips on screws or cut them off?
The new toilet is smaller and so will sit forward of the wall and i'll need to fit some wood to locate cistern against. The waste goes vertically into floor and I hope the old pan connector comes off easily!
Always a challenge!
Thanks all
Rocket
Me personally I'd Vax the water in the pan up then smash it. Don't spend an age messing around trying to get the screws out.
Post up a pic of the swan neck. Modern pan might not fit the same and you might need a pan connector with a tighter bend like this one:
http://www.NoLinkingToThis/p/mcalpine-wc-conq-90-space-saving-pan-connector-110mm-outlet/23036
Normally it's a case of breaking out the old one close to the floor and inserting the spigot of the new pan connector and sealing it up, but a pic would help.
