One noisy upstairs radiator
View the thread, titled "One noisy upstairs radiator" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
Hi all,
I registered on here with the hope you’ll be able to help me.
I have one radiator which when the CH is turned on it makes a loud rushing noise (the only way I can describe it) it’s loud enough to wake you up in the morning.
The only way to stop it is by turning the pump down but then the rads furthest away from the pump will only warm up slightly.
The rad in question does not have a TRV, it’s just the normal valve and is the first radiator in the cycle.
This is the only radiator with any issues and all of them have been bled.
Thanks all.
Reply to the thread, titled "One noisy upstairs radiator" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
Qzwxec10,
Qzwxec10,
