View the thread, titled "Overflow help" which is posted in UK Plumbers Forums on UK Plumbers Forums.
U
Unregistered
Hi.
Outside my property, looking up towards the roof. There are 2 little white pipes sticking out. 1 is leaking water. Not just a trickle. Its quite fast!! Its coming from the cold water tank in the loft!
I have emptied the tank by turning off the stopcock and running the hot water tap in the bath. Then i slightly bent the brass pipe (which attaches to the ballcock). Then refilled the tank.
Overfill pipe is still leaking.
Have I not bent to brass pipe enough?
Imgur
Im rubbish at diy!!! I did theabove based on google searching!
I will have to watch the video tomorrow when I get into a wifi zone as watching a video eats my data!!
when I lift the arm up the tank stops filling. So is that definately the washer? Or do i need a full new brass arm?
Get a complete new ball cock, circa £5.00 Unnecessary to completely remove original as part entering tank can be split and new fitted at this point.
So based on the photo I have shown above does it all look ok? Shall i just get a new washer? Where does the washer bit go?
It goes in the plumbers hands when he is changing it
Save yourself the grief and get a plumber in to change it
From your questions you do seem very novice. This could go horribly wrong.
If it is the washer that needs changing it is a quick fix for a plumber and you are assured that nothing else will be damaged in the process
We are all for DIY but if your not competent then it isn't going to end well
As they say above - Get a plumber in. I wouldn't bother replacing just they washer. A lot of the time the ball valves get so corroded with limescale that you wouldn't undo the service nut anyway. Best just fitting a whole new ball valve.
a plumber would charge you an hour labour plus parts. it would take him more time to get his steps and tools out the van than to change it.
Someones just said its almost without doubt the diagphram has split and that my valve isnt a normal one. Is that true? Photo is in my first post
Alot of the time the diaphram washers go hard leave a back mess when you take them out.
Reply to the thread, titled "Overflow help" which is posted in UK Plumbers Forums on Plumbers Forums.
