Sep 26, 2020
23
Surrey, England
DIY or Homeowner
I am struggling to find a replacement bath panl for my bath and would much appreciate advice on where I might get one or alternative options.
The bath was bought about 5 years back from Plumbworld. The supplier confirmed it’s not longer in production. It's a Ceramica 1700mm Bath Panel Left Hand. Original part code NAP001. The panel has a tongue and groove feature (top).
Size is 1700 x 525 with a 204 depth for the 'P'
If an exact match can't be found are there alternative options cheaper than getting anew bath?
[automerge]1601119296[/automerge]
I should have mentioned - I (and the bath) are in Surrey, England
Can make one out of flexible tiling board(E.g. wedi/marmox etc).
Make a frame, bend board to suit and attach, skim over the cut grooves with tile adhesive - this stiffens it all up.Tile with mosaics once dry.
This looks great but will not be a cheap option.
It is not always possible depending on design of bath; ie how much space you have for frame.
Alternatively you can square off the p and tile a straight vertical. You end up with a little “shelf “ you have to step over to get into bath - it ends up looking like a drop-in bath. Cheaper and easier to do than the above, but needs a little space in front of bath ( couple of inches or so)
