View the thread, titled "pan connectors?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
mutley racers
Subscribed
Hi every one, just needing a little bit of advice from you guys. Can you tell me if it is possible to attach a strap on boss to a pan connector for the waste of a basin? Is this against the regulations? Or will it course induced siphonage?
The toilet is in an outside shed and the soil stack goes straight down into the floor with an angled tap connector.
Look forward to your advice
Mutley
hey thanks mike. The only problem is is that the pan connector is concreted in the ground. But i asume that if you can buy them then i can just cut the hole and then add the boss.
Reply to the thread, titled "pan connectors?" which is posted in UK Plumbers Forums on Plumbers Forums.
