Nov 1, 2013
21
Hi all,
I hope you can help me on behalf of a friend who has been without heating in her old stone building for five days now!
Basically, her builder has installed the wrong boiler or something. She needs to get hold of a union for a U16 meter to a 35mm pipe. Does that make sense???
Hi all,
Yes.
It would make sense to a Gassafe engineer or Her builder if he was Gassafe registered.
Hi I'm Kelly's friend. So all is ok with the boilers. We have a total of 100kw of gas usage if all appliances are on together. We had to have a u16 meter fitted and pipes changed to 35mm. We've done this but nobody seems to have the part to connect the 35mm pipe to the new U16 meter. It's a big mess! If anyone can help with the part I would be grateful.
A Gas Safe registered engineer would know exactly what you need. Is your builder Gas Safe registered?
gas safe engy is needed and a commercial one at that
also depending on distance and site requirements that 35mm pipe sounds small
also do you know if the person who installed and calculated what size pipe is required is gas safe
Reactions: 2 people
We shouldnt really be showing parts and encouraging this the OP needs a correctly qualified gas Safe engineer
