Part p
View the thread, titled "Part p" which is posted in UK Plumbers Forums on UK Plumbers Forums.
I did the defined scope part p in 2005.
I now believe this route into registration with a scheme provider is now closed. At least 1 employee must be fully qualified and be classed as an inspector ??
Well done mate at last someone has pointed me in the right direction. Tried getting advice from the electrician forum and God it's hard work
You just need to know the right people to ask 🙂 and that's where I got my info from it being axed
I can get on a part p from a dozen providers within a 30 second google search.
Part p is not being axed - it is a current building reg.
Ohh yes - Of course it means nothing.
And they may also phase out gas safe.
Do a google yourself - i have been considering doing it myself and have found a multitude of providers both locally and nationally
well you never know it might go back to corgi and already 17th ed 🙂
with the additional costs of being with a competent person scheme and the cost of tester, I get a sparks in if it needs a cert. unless you are going to do new circuits etc then need to do 17th
Tester £400 Sh off eBay I am insured for plumbing and property maintenance so pretty much everything bar gas work, then it's jusn annual calibration and members £450. Domestic installers course £520
Bare in mind my sparkie charges £250 to do a 10mm circuit for a shower. For the extra work I pick up it will more than cover it, then got the extractor fans I just say no to. It's a no brainier to me! I also fit kitchens it's only going to benefit and make me more money. Far more professional I feel, yes it is cutting my mate out the loop but that don't feed my son
That doesn't mean anything and they could just state you must be 17ed which = part p
What youve just gurgited doesnt mean anything
But if you looked yourself you would end your own argument - and You state "could" lmao
What sort if a bloomin argument is that...
You state your in the know - what...youve overheard a disgruntled Electrician pee and moan about wannabees entering via the route and how they think its wrong.
I seriously doubt your in the know.
I dont think you party to what the IEE are tabling or central government are considering re building regs refinements.
But what i do know - and what can be seen with a few clicks of a button is part p is current and still accessible.
That Christ for that at last got a answer from the horses mouth called niceic told them what I wanted. ONLY need a 17tg edition course 3 days then pass there site assesment and there competence test
Just called nappit and they want 17th edition, nvq, 2 years experience lol how can they differ so much
They are different bodies with different accreditation standards. There is another one and i cant remember the name that needs less
That Christ for that at last got a answer from the horses mouth called niceic told them what I wanted. ONLY need a 17tg edition course 3 days then pass there site assessment and there competence test
What exactly did you ask for?
Did they tell you what was involved the Assessment and Competence test?
My advice is to buy a copy of the 17th edition regs AMD3 and a copy of the on-site guide AMD3 you will need these to join a scheme anyway.
When you get them have a good read and see if you still want to do electrics as you will need to know the regs well so you know that you are doing the work correctly.
Said that they come out on site to check a job ie doing a spur or installing a extractor fan. Then a online assessment test
They would need to see either a job that required a full electrical installation certificate (re-wire, consumer unit change or new circuit - e.g. shower) or several Minor works certificate jobs.
They are only interesting in your ability to perform safe isolation and follow the correct procedures for inspection and testing.
Just because you only want to do a small amount of electrical work you still need to know the complete range of information. An Electrician is an Electrician you cant pick and choose bits you want to do.
An example of one of the questions is "What is the max Zs value for a circuit with a 32a BS60898 breaker", fairly basic question but essential to know the answer.
Reply to the thread, titled "Part p" which is posted in UK Plumbers Forums on Plumbers Forums.
tommy1712,
Jamiethackway,
