Deaf Cat
Hiya,
My Dad used to say that Pegler was one of the best quality makes of brassware.
When I first started plumbing a few years ago I bought what my local shop had. After coming across a few isolating valves that leaked once touched, I thought there must be a better quality type around that lasts, so found Pegler brassware at screwfix, my local shop wanted far too much money for Pegler stuff.
So I've been buying Pegler isolating valves and lever valves (full bore) as well as stop cocks, thinking, decent brasware that will last.
Over the last year say, I've had, must be getting on for about 8 Pegler isolating valves, just installed, water back on, and they just don't turn off, even when the screw driver slot says they are shut, last thing that one wants a!
The full bore lever valves seem much better quality, but it does make one wonder, after the careless balls up of making and sending out isolating valves that don't isolate.
A couple of the 15mm stop cocks I've had don't fit on a 15mm pipe, I've had to hammer them on! Quality slipping me thinks.
Oh and to put the icing on the cake, a customer wanted a thermostatic bath mixer tap that does a shower too, so recommended Aqualisa and Peger, they bought the Pegler, 3 days later I was back to change the thermostatic cartridge....😡
So, I'm feeling a little lost at the moment, my chosen so called quality brassware is a bit of a shambles, do you have any prefered brassware manufacturer that you know is going to lead to no call backs and no installation problems?
I appreciate any thoughs or comments,
Cheers,
DC
Cheers,
DC
