I am having issues with the above boiler. Basically the stat for the heating on the boiler doesn't regulate the temperature at all, even set to minimum the rads get roasting like its on max. Tested the thermistor 3.5k ohms at 60-65 degrees, so all ok. Technical advised me to change the pcb.
Changed the pcb and still have the same issue. There is only one thermistor on this boiler for hot water and heating. The hot water control thermostat on the front of the boiler is also acting like the stat for the heating side, so with the heating running if you turn the water temp down then the boiler shuts down as if you turned down the stat on the heating side. Technical passed me on to 4 different people all with no idea whats going on. Ive been advised to change the thermistor, even though the readings are fine in relation to temperatures. Also to replace the board, which is brand new. What are the odds of a brand new board having exactly the same fault as the existing one!
Anyone had this problem before? I hoping Gas Man comes to the rescue as he is the resident expert!
