View the thread, titled "pipe run" which is posted in UK Plumbers Forums on UK Plumbers Forums.
pauls
just wondering if it would be better to take 22mm off pump to shower and reduce down to 15mm just before i take the tails up the wall. length of run is about 3 metres or should run be any different in 15mm.
pump is 2 bar
cant remember the make customer ordered it when he ordered the suite
The pipe sizes requires will be in the pump manufactorers instructions but if 2 bar would assume should be run in 22mm,this will require to be 22mm to shower mixer valve,including up wall run
cheers puddle
its a mixer shower i dont think i have ever come accross a 22mm mixer if it is 15mm i take it the best place to reduce would be up the wall run before spliting off to marry up with mixer valve
Reply to the thread, titled "pipe run" which is posted in UK Plumbers Forums on Electricians Forums.
