Pipe squeezers - what do you use?
View the thread, titled "Pipe squeezers - what do you use?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
M
Masood
As per the title, I came across a house where there was no outside stopcock and Thames Water couldn't find it either. They reluctantly shut the street main down so I could bung a shutoff valve on, but the guy suggested that I could have squeezed the pipe.
Do you guys do this? Sounds a bit risky to me! The pipe was 22mm black plastic, LDPE I think. What squeezers do you use?
I bought one from suppliers works a treat
Just a sort of vice with sliding bar
Ill look it there a name on it mate
i did my own , get 2 small (8 inch maby rough guess) pieces of hollow steel tube and drill holes in them so a threaded bar will link them together so as you tighten they come closer, ill post a pic up . not very good at describing things!
i did have a propper one at one stage got it from toolstation but at the moment i am using a 8 inch G cramp and 2 peices off half moond timber flat side to the clamp round side onto the pipe works a treat
Your description makes perfect sense, mate! Going to have a rummage around in the shed, I know I've got some steel tubing and threaded rod...
I saw these mentioned on the forum ages back, seen them in the tool station book £25
Toolstation > Hand Tools > Plumbers Tools > Squeeze Off Tool
I never got any, the idea just seemed wrong, possible damage to the pipe.
I suppose I am being overly cautious, does the pipe wall always just bounce back to where it was before?
i posted a link a while back http://www.ukplumbersforums.co.uk/plumbing-tools/31965-anyone-got-one-these.html
i've never had any problems with them, the pipe just about returns back to the round afterwards, if not. just sqeeeze it back with your gland pliers.
I've only ever used it on poly that isn't very old. The pipe don't go back perfect but near enough.
i wouldn't risk it on old poly in case it decided to split.
bit risky mate using timber 😡 , if you must go the diy route, better to use metal
Come on chaps its all there on TINTERNET £30.00 at a shop near you or AMAZON
not something i keep with me all the time but i allways have some half moond timber and g clamps my propper one will be in the garage or shed somewere i think i have squeezed mains at the most 3 times this year
If that "G" clamp slips off I don't know what you will do Woody
Has anyone ever had a pipe split or burst when squeezing it? This pipe that I was looking at was at least 1970s. I wonder how flexible it still was? And if it did burst, I'd have been in deep, deep doodoo as there was no way of shutting the mains off at all... I can see that they'd be very useful, but I'm wondering how big a risk it really is??
You could try freezing it, no no please, I was only choking, don't squeeze too hard and take it slowly
Reply to the thread, titled "Pipe squeezers - what do you use?" which is posted in UK Plumbers Forums on Plumbers Forums.
Masood,
happyflyer,
