View the thread, titled "Pipes vibrating" which is posted in Make a suggestion about the forum in general on UK Plumbers Forums.
Evening all,
Some advice please. I went round to a customers home to do a few small jobs.
One I just can’t cure.
When the cold water is running the pipe around the house vibrate. It’s a newish build property and is mainly poly pipe running through joist and in walls. The flooring is large sheets of OSB/Chipboard with no access points. When the water has been off for a period of the time, they noise seems to disappear for a few days and then returns.
The cold water has pressure reducing valve fitted and also a pressure and temp valve on the hot water storage tank. It’s a combi boiler but the house has 4 bathrooms, hence the need of extra hot water storage.
The noise isn’t the standard water hammer as it occurs when the water is running and not when a tap or toilet inlet valve shuts off.
Any suggestions would be appreciated.
Thanks in advamce
Evening all,
Thanks in advamce
I had that problem with a customers property. Could not get to the source of the water hammer without taking half the house apart to access the pipes (loose pipes). So I fitted a water hammer/arrester to the mains under the sink just after or as close to the stop tap as I could and it solved the problem. 20 minutes work, job done.
Hope this helps.
Hope this helps.
I was looking at that earlier and wasn’t sure what they actually did. I understand the principle of them. They absorb the pressure when a valve/tap is closed off. The issue I have is the noise is there when a tap or valve is opened.
Thanks for the reply it’s much appreciated.
Reply to the thread, titled "Pipes vibrating" which is posted in Make a suggestion about the forum in general on Plumbers Forums.
