Pipes vibrating
View the thread, titled "Pipes vibrating" which is posted in Make a suggestion about the forum in general on UK Plumbers Forums.
Evening all,
Some advice please. I went round to a customers home to do a few small jobs.
One I just can’t cure.
When the cold water is running the pipe around the house vibrate. It’s a newish build property and is mainly poly pipe running through joist and in walls. The flooring is large sheets of OSB/Chipboard with no access points. When the water has been off for a period of the time, they noise seems to disappear for a few days and then returns.
The cold water has pressure reducing valve fitted and also a pressure and temp valve on the hot water storage tank. It’s a combi boiler but the house has 4 bathrooms, hence the need of extra hot water storage.
The noise isn’t the standard water hammer as it occurs when the water is running and not when a tap or toilet inlet valve shuts off.
Any suggestions would be appreciated.
Thanks in advamce
Evening all,
Thanks in advamce
I had that problem with a customers property. Could not get to the source of the water hammer without taking half the house apart to access the pipes (loose pipes). So I fitted a water hammer/arrester to the mains under the sink just after or as close to the stop tap as I could and it solved the problem. 20 minutes work, job done.
Hope this helps.
Hope this helps.
I was looking at that earlier and wasn’t sure what they actually did. I understand the principle of them. They absorb the pressure when a valve/tap is closed off. The issue I have is the noise is there when a tap or valve is opened.
Thanks for the reply it’s much appreciated.
I would fit the hammer/arrester first and take it from there might save a lot of time.
Many thanks
That’s the route I am going down.
I have spoke to the customer and they agree. However they added that the noise only seemed to start when they fitted a washing machine. With this in mind, would you connect the arrestor near the washing machine or just after the stop tap under the sink?
Many thanks
Many thanks
Many thanks
What a shame you didn't mention the washing machine from the beginning.
Try to fit a shock absorber as close to the stop tap as possible. That way the whole house (water wise) is covered.
Consider using an endoscope / boroscope to find the run(s) that are not properly secured. Take when drilling the inspection holes not to damage any pipework/wiring!
Reply to the thread, titled "Pipes vibrating" which is posted in Make a suggestion about the forum in general on Plumbers Forums.
Fusion,
Chuck,
