View the thread, titled "Please advise / shower" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
rocketmanbkk
Hi
Replaced a shower pump and on sat replaced new shower.
All working, looking good.
Today get a call no hot water.
Went there, pump won't kick in in hot. When you turn pump upside down in works but put it back stops again.
Took shower off wall, turned pump off, cold great (tank fed) hot weak - was 3 Ltrs per min now just 2.
I think this issue is the pump not being fed enough hot. I changed the hose as it was twisted a little and pulled the mesh filter out. Still the same.
Not sure what to do, it's weird that in Sat it worked now not.
The shower is a Triton and 0.1 bar ( I was careful to get that right).
Anyone help with this one please?
Rct
Air locks, story of my life.
How would you clear it please? I can try before the SOS call.
Depends how its set up Jay....air will collect at any high point so if the flexi's into the pump are bent over it may be there or if the cylinder outlet is straight off the top without a surrey flange, then the pump can draw air down the vent pipe easier than water from the cylinder causing problems that way. No shortage of potentials really.
Nope, toxic had a look, I explained what I'd done, pump not kicking in on hot but flow when valve off wall.
Took valve off again, he undid elbow on hot and removed the mesh filter that was fully blocked after 1 days use!
Put back together & working fine, pump kicking in, all ok,
I'd have never ever have looked or even knew the elbows screwed off.
Great piece of knowledge gained.
I thought the watermills come with the flexis detatched and we have to screw the elbow flexis on? also insert the filters , they maybe all come together now
Reply to the thread, titled "Please advise / shower" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
Thread starter
rocketmanbkk
Joined
Location
Langley, Berkshire
Thread Information
Title
Prefix
N/A
Forum
Start date
Last reply date
Unsolved
Thread Tags
Tags Tags
shower
rocketmanbkk,
Toxic Ted,
