Please can anyone answer 3 questions about central heating?
View the thread, titled "Please can anyone answer 3 questions about central heating?" which is posted in Central Heating Forum on UK Plumbers Forums.
Send a picture of the trvs and we will tell you how to unscrew the head from it on a temp
Basis.
Thank you. Attached photo! I'm a female pensioner! If you tell me what to do, I'll be grateful but I might need help!
The bit that I have circled in the picture needs to be undone and then the head will come off the trv. They may only be finger tight but if you struggle to grip things you may needs some adjustable grips.
Why won’t you remove the trv heads or move the stat
I asked the engineer if the TRVs were causing the problem and he said they were ok. I'm going to try to remove the heads (I'm a female pensioner which is why I'm trying not to meddle too much myself but would rather get an engineer in to sort out the problem!). I have difficulty unscrewing parts that are tight. I tried to room stat in the hall and I didn't notice a difference, but I'll try relocating it again.
Sorry I wasn’t having a go but it had been said several times
No I know you're trying to help, but I've put all these suggestions to an engineer. He said draining and refilling the system wouldn't help, that he had no concern about the new TRVs that had been fitted, that I would need to keep bleeding the system as the noise was being caused by air, that the location of my room stat is not an issue. I do have faith in what he told me and he's offered to come back but it's taking too muc to solve the problem of the gushing sound in the pipes and rads but I wondered if I should be better informed or I'll just keep going over the same suggestions!
The valves on the other end of the radiator may be restricted down to much. That causes noise.
Ok that's interesting. Would it be a gushing, coursing noise as if water is being forced through the rads and pipes? It's much worse if the boiler pressure is up to maximum. I've turned down the boiler pressure and eliminated the noise from the rads in my living room (still noisy in the hall and bathroom but they don't bother me). Trouble is, with the boiler pressure turned down, of course, the rads don't get so hot (ok for now but might not be ok when winter sets in).
How are you changing pressure??
1) I am told on this forum that the water would have to be above 100°C for any steam to remain as steam. My own experience makes me wonder if this is not the case, and I think I read somewhere that H2O can remain as gas or liquid over a range of temperatures.
2) Hard to answer from that description.
3) It can be normal for the rads to go stone cold, but not for you to freeze. I would suggest the hysterisis on the thermstat is too high (normally not adjustable these days, so new stat required), that the stat is wired incorrectly, or the stat is incorrectly located for your needs.
One problem is that the same room at the same air temperature can feel either hot or cold depending on whether there is a hot surface (e.g. a radiator) in it. The thermostat works on air temperature, so is unable to know if the radiator is hot or cold, or how warm you feel.
I have often considered in dull moments that a pneumatic time switch that turns the heating on for 20 minutes whenever you press it (i.e. heating only comes on when you decide you need it) might be more effective at keeping the rooms a good temperature and saving energy than a thermostat, but conventional thinking goes against this!
To be frank, turning the TRV head to the highest setting would be nearly as good as taking the head off altogether, in most circumstances.
10 out of 10 for doing it yourself
The advice on here is the best
Let us know how you get on
That's lovely of you, thanks. I've moved the room stat to the hall and removed one of the TRV's on the rad closest to where I sit (and therefore the most annoying rad!). The other 2 TRV's in my lounge won't budge without a wrench, which I don't have. But anyway, I'll see how the system behaves this evening (it's a lovely day so I won't learn much til the temp drops later, I guess). I have a friend calling on Sat, bringing a wrench!! I honestly don't mind calling out an engineer, but we don't seem to be trying anything new and I don't want to waste his time, so that's why I'm trying things myself! Thanks for your support.
Thank you. That might be why my engineer wasn't concerned about the TRV'S. They're always on the highest setting. Anyway, I've removed on TRV very easily and relocated the room stat to the hall. I can see how the system behaves later. Helpful also to know it's unlikely to be the noise of hot water I can hear in the rads and pipes, though.
Genius idea! I get really cold and give in and turn up the temp on the room stat to make the boiler come back on. Then I have to turn it down again when the room starts to overheat! I try not to as it can't be right that I'm constantly meddling with the room stat! I've been wondering why it can't be on a timer instead - 20 mins on and 20 mins off, say, would keep the temperature constant.
Reply to the thread, titled "Please can anyone answer 3 questions about central heating?" which is posted in Central Heating Forum on Plumbers Forums.
Martell,
Martell,
