N
nadakuss
hi all i just registered i really need some help/advice i am at my whits end.
i am a housing association tenant and on Sunday the 25 of Nov my heating and hot water stopped working this is when i discovered that my Emerson heater doesn't work either so a plumber came out on Sunday thought it was the control panel in the airing cupboard changed it no difference she said she thought it was the the three port valve but didnt have one and it would have to be ordred someone would contact me on monday. it got to 2ocloc monday and i called them to witch i am told no job has been raised and its too late in the day now someone will be out tom. so a guy came out on tuesday i was expecting him to change the three port valve and everything to be hunky dory. no. he had no three port valve and his job card said remove boiler casing. after a few phone calls he found out that he was supposed to be meeting a sparky here to remove the housing for him. but he was a nice guy and looked into the fault he said the three port valve was fine and we needed the conroll board on the side of the boiler. he would have to order it and then it would be fitted. thurs the part arrives and im straight on the phone to find out when its getting done they said someone would be out today. great news. then the head technitian calls 10 mins later he has seen the job reports and he thinks they have all got it wrong it needs a set of sensors witch would have to be you gussed it orrderd!!! fri the head tecnitian comes out fits the sensors no change fits the control board no change then he says it the main pannel in the boiler with the on off switch on it. he has one its 2.5 hrs away. he comes back fits it no change. he is trying to find the falt messing about with the wiring and he gets a small piece of wire and briges two connections in the boiler it will run.. he leaves it in there and goes away for the weekend. the more i think about it the more im wondering if this is safe. i have a wife a 18month old baby a 3yr old and a 7 yr old with asthma we are very fed up and up till fri night very cold.
any help advice greatly appriciated on what to do. thank you
sorry if this is in the wrong section
