Plumbing or Appliance Fault?
View the thread, titled "Plumbing or Appliance Fault?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Had a new Kitchen fitted just before Xmas with integrated Washing Machine and Dishwasher (never again!) Appliances are located around 3.5m away from the sink, in a corner, sink one side, appliances on the other. All hose lengths within manufacturers recommendations btw.
Washing Machine drum fills with dirty water after a couple of days of no use, one time it was over the level of the bottom of the door- cursory Google search suggests issue with plumbing as does the Manufacturer's website FAQ's. Plumber says call Manufacturer to sort, but loathe to do that as I'm not sure I'm going to get anywhere?
Anyway I know it would be really helpful from the picture attached to highlight which waste hose is Washing Machine and which one is the Dishwasher, but I don't. I'd assume the Washing Machine waste is the up and over on the left - if anyone has any ideas or advice, I'm "all ears".
As the washing m/c is the one back filling I will guess it is the hose on the right because it is pointing downwards. Run one m/c on a short cycle and hold the hoses during draining and it will be clear which is which.
My assumption was incorrect - the hose on the right vibrates when you hold it during the cycle whilst the left one doesn't. So I'm assuming that's the problem and that hose needs extending (both hoses have extensions already) to get it up and over and that's causing the issue?
bad plumbing the hoses should come from the top and down, plus you always have w/m or d/w under the sink use .
McAlpine
Part Number: 24722
Manufacturer's Part Number: WM11
McAlpine Twin Nozzle Sink P Trap - 40mm, 75mm Seal​
Reply to the thread, titled "Plumbing or Appliance Fault?" which is posted in UK Plumbers Forums on Plumbers Forums.
balders99,
balders99,
