Shapingstuff
I've had a heat pump installed and there has been two leaks on copper solder joints internally. And there are several threaded joints around the tank that also water showing. I've been fairly patient despite resultant damage. I've been told this is quite normal when the pipes heat up (not about 50 in this case)? How normal is it for a professional company to have this many problems with basic plumbing? Should I be concerned? Is this incompetence?
Any Plumber can have a bad joint for all sorts of reasons. Through testing thoroughly, they should present themselves, be repaired and hopefully never come to the attention of the customer.
Did they seem to be in a rush?
Bad joints are like bad food in a restaurant, we all get it but a decent chef tastes their food and leaves it in the kitchen bin and remakes it so customer doesn’t even know about it (just has to wait a bit longer). And a decent plumber picks it up and as above.
  • Agree
Reactions: Last Plumber
That's a crackingly good analogy if ever I heard one.
