Poor cold bath flow!
View the thread, titled "Poor cold bath flow!" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Dan the plumber
Evening All,
But of advice please guys....
Started first fix on a bathroom refit today and discovered flow to (CWSS) cold bath feed is terrible to say the least.
This is now the 2nd time first fix has been done as "plumber" previously c*cked things up so took out his handy work & reran pipes etc today!
Customer advised perfectly good flow before plumber came along! Hot flow to bath is fine as is all other taps throughout the house-any ideas as to why flow is so bad!?
Thanks in advance guys & gals.
air lock ,gate valve collapsed , debris in pipe work ,did you check cold water tank (mouses are know of a good swimmers but some time they can not escape and ...... )
Thanks for speedy reply.
Yeah checked tanks today and they actually nice and clear as far as tanks go!
Iso's have been fitted on both hot & cold pipework but hot is fine-think this may have an influence!? I did think it could be an airlock as system as been drained a fair few times so will have a go at flushing it tomorrow-any recommendations as to best way to flush through!?
Thanks again for the help.
Stick a wet vac in the tap and open the cold - if it's an air lock thus should pull it through.
Has the other plumber used ptfe on the iso valve? If so he may have blocked it up.
It was speedfit city but have whipped those out today, must have cost him a days wage in fittings alone!!!
Can't see that he has used any ptfe on Iso's tho!
shouldn't need ptfe on isos if done correctly. what is the flow like without the taps connected? could be unseated washer in the tap.
Yes ran all in copper.
Have not even attempted to connect to taps yet as flow is so bad! It's only on that particular tap feed though but was flowing fine till he had a mess!
could be some crud in pipe. can you back flush it with mains? or forward flush from tank using tank feed
Will give back flush a go tomorrow and hopefully that should flush out any rubbish in pipework!
Bit of a thick question here: feed coming out of top of cylinder has been Tee'd off before it gets to main feed/vent pipe....why!? Can't see where this run of pipe goes and it's on this run that a gate valve has been installed! Still getting full flow to all hot taps when gate is closed!?
I thought it could be something like that but the only shower in property is an elec shower in the en-suite and by the looks of it, a dedicated cold feed has been run for this in the loft!?
Just to clarify I know there should be no ptfe on ISO's but seem it done where the tape is actually restricting the opening!
Fair point - will try back flush tomorrow and let you know how I get on.
Thanks again for the help, appreciate it
Morning all,
Just a quickie (as the actress said to the bishop!)
Problem sorted...think it was a combination of an air lock and half a ton of loose solder in the pipework!
Connected to mains and back filled=jobs a good'en
Thanks again for advice all.
Dan
Evening All,
could be many things, try tap first and then trace back, could find it easy could be a long time, such are the nature of these things im afraid
Reply to the thread, titled "Poor cold bath flow!" which is posted in UK Plumbers Forums on Plumbers Forums.
Dan the plumber,
fuzzy,
