View the thread, titled "poor supply of hot water to kitchen tap" which is posted in Bathroom Advice on UK Plumbers Forums.
L
lesmuscroft
I live in a bungalow, I have a NEWTEAM pump that supplies both hot and cold water from each tank to my shower. Is it possible to connect the hot water output from the pump to both my shower and my hot water supply to my kitchen tap.I presume the connection if possible would have to be after the blow off branch
I'm sure you don't want that noisy Newteam pump (Duraspeed?) grinding away everytime you turn the tap on? I would check with Newteam if you can do it as advice seems conflicting. Some say you can some say you can't.
Reply to the thread, titled "poor supply of hot water to kitchen tap" which is posted in Bathroom Advice on Plumbers Forums.
