View the thread, titled "Potterton boiler help" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Drewzle89
I have a potterton suprima 60L.
I accidentally drilled through a plastic heating pipe today. I knocked all the valves from the upstairs water tank in order to stop the flow. All was fixed and sorted however the boiler won't work. Weve turned on all valves again having trippled checked but the boiler clunks couple of times and defaults to red. It wont reset for a further 30minutes. Any ideas how to fix? Do i need to wait for the tank to refill? Theres no pressure gauges on these old boilers im aware of and i need help. I have a little one and need hot water and heating
thanks
If all was ok before then it sounds like air in system. Make sure any valves you closed are open and bleed the radiators. Make sure there is water from the radiator bleed valves.
Now try boiler again. Hold in reset button and see if kicks in.
If no luck with this then you may need to get someone to look at system.
Hi thanks for quick reply. I did bleed two rads for a min each and just ran clear. Any ither ideas?
Does the boiler fire at all ? if it does but only for a short time, its possible that pump has stuck
Ye it fire for around 30 seconds. Then clunks and goes off and clicks off with intermittent red light on pcb. Can you reset pump or anything?
Yes, centre of pump large silver screw, remove this (May get a small amount of water but nothing to worry about) insert small screwdriver into centre and give it a couple of turns should solve problem
When boiler cools push reset as soon as she fires turn the boiler thermostat above to off, this will stop boiler from firing up & overheating but will keep the pump going for a while,
go check that the pump is running you should be able to hear it turning if not you will need to remove that cove & use the screw driver.
If you have a old style pump there should be a speed selector on the side if it isn't already turn it up to III then back down to what it was set to a few times.
This should help to knock the trapped air out of the system pipe work, do you have any air vents on the pipework.? if so, open them & bleed out any air.
On your programmer (time clock) turn off the heating & switch on the hot water, it is much easier to clear the air from this first.
Turn up the boiler thermostat & boiler will fire up, if it start to make that noise again turn it off straight away on the stat.
Reply to the thread, titled "Potterton boiler help" which is posted in Boiler Advice Forum on Electricians Forums.
