Was the APS from a working boiler?
I have not got back to this boiler yet, when I do I am going to try a used PCB first and maybe then a used APS which I have taken off a working boiler which I have replaced with a new high efficiency condensing boiler. I have already blown down the APS tubes.
Not 100%sure but Is there a Venturi on aps tube before aps, if there is check this? You may have already by passed this by blowing down the aps if you went straight on to the positive connection on it.If so got to be slow running fan or flue.
Had ridiculously high emissions from profile before an I put it down to glue & turned out to be slow running fan, could be same in your situation but the fans got to point where it won’t even operate the APS
I have checked the Venturi and it is not blocked, have alsolconnected a tube externally to APS to activate it
Sounds more like APS then mate,can’t remember but is it a 3 wire or 2?
*just read you’ve already tried a new one,I’m out of ideas but be interesting to know how you get on
Forgive me for not reading all this again.
Have you checked the obvious like spark gap, electrode, strike point, earthing, HT lead, etc
Earlier on he said that he wasnot getting a spark at all,even disconnecting HT lead from pcb an bridging from the pcb to a insulated screw driver
I have checked all items you detailed and even had a friend of mine take a look at it. This friend works on gas appliances only. I hope to have another look at it over the next day or so.
I seem to remember the white sparking lead is no longer obtainable. Not sure if generic ones will work
