Power flushes / rads not heating up - HELP PLEASE!
View the thread, titled "Power flushes / rads not heating up - HELP PLEASE!" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Can you get to the small tank in the loft and photo the water that's inside it? Dirty water inside the tank can help diagnose problems.
Also with the heating on, run your hand over the radiators, They should be warm / hot all over. Any cold spots will indicate a build up of sludge within the system.
That’s a good idea, I’ll go up and take a look when I have some good light...thanks for the idea
The drain cocks seem in good condition should be quite easy to drain the system after you have cleaned it, but a magnetic filter would be a good idea, than add inhibitor. It would make the water hotter I mean more efficient if that is the problem.
Reply to the thread, titled "Power flushes / rads not heating up - HELP PLEASE!" which is posted in UK Plumbers Forums on Plumbers Forums.
Mandy Cowlishaw,
shocking mod,
