View the thread, titled "Power flushing boilers" which is posted in Boiler Advice Forum on UK Plumbers Forums.
T
tommy1712
I understand that it's not advisable to power flush back boilers. What other boilers would people recommend not flushing.
I am kind of after a bit of a list what not to flush
if I bypass every boiler then I could just crack on with fx2 and neutraliser??
It would be quite hard to bypass some boilers. I would avoid power flushing most condensing boilers if on a bad system and do the boiler on its own.
You are not pushing anything through the boiler that has not been pushed through 100’s of times, before. Always use a good pump. Thats why we use Kamco Clearflow CF90 Quantum powerflush pump which can deliver 150l/min flow. The all important flow rate is achieved without increasing maximum pressure beyond 1.8 bar, to ensure that no damage will be done to a heating system. The flow rate is more than double that of most power flushing pumps on the market, enabling it to remove more debris from a system and in less time.
Reply to the thread, titled "Power flushing boilers" which is posted in Boiler Advice Forum on Plumbers Forums.
