View the thread, titled "power shower" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
M
marchowe
hi i have been asked to fit a power shower for a customer and the system he has is a direct system with a hot water cylinder in the ac with a cwsc directly above it. is it possible to install a power shower with this system will there be enough head pressure to take the 15mm copper up through the loft and back down to the bathroom. ant advice please thanks
Depends on the distance from the water level in the cistern to the shower head. A pump will work it if it is not enough. You may need to fit an automatic air vent at the top of the loop to prevent airlocks.
Reply to the thread, titled "power shower" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
