powerflushing boilemate 2000
View the thread, titled "powerflushing boilemate 2000" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Don't see what there is to Achieve.
The sludge would probably not come out. Probably best to take cylinder outside and wash it out
i have been to a house today that has had in the last month, a new plate fitted, a new hws primary pump and a hws flow sensor fitted. i hadnt seen one of these before but the pump sound to have pulling in a blockage or low water. There is sometimes a limited amount of hot water and the pump runs up to speed, as i ran it up at one occasion the plate outlet was only 2-3 deg warmer than the water coming in.
Apparently it was much better when the plate was changed for a week or two.
I checked the f+e mounted on top and found a load of slime about 1" thick. i suspect this may also be growing in the main cylinder blocking the pump inlet or possibly only blocking the plate.
Has any one else seen anything like this, the water is clear in f+e but doesnt appear to have any inhibitor.
Has anyone power flushed for slime and what did you use.
I wouldn't bother there such a pain over complicted, some have got three 15/50 pumps in. rip it out..
Yes, I've seen the slime in the F&E.
Sounds to me that only one sensor was changed on the unit you looked at. You should change the wet sensor and the dry sensor at the same time. The pump speed is controlled by the sensor (its a modulating pump).
thanks Danny, the pump tries to circulate water with no or intermittent flow. it starts and stops slowly so i dont think the problem is there.
The pump starting and stopping slowly...could very well be the sensor mate.
You said it's had a new pump. Did it get an X18 15-50 or just a standard 15-50?
Yes these are junk, but can normally be repaired. Like a few people have said, an unvented would be preferable. As long as the discharge pipe work is easy.
I've been to some installed in the middle of a development, where proper termination of the discharge on the unvented wouldn't be easy to acheive.
thanks Danny, yes its the x 15-50 pump and even when the pump runs at full sped the domestic water is very cold. and yes its in the middle of a new build.
The pump isolation valves on these are prone to leaking and can jam in the wrong position. You definetly are getting a flow through the pump? Might be an idea to drain it down and check, change the valves. You could then also remove the lower immersion element and have a look in the cylinder for a build up of sludge.
You could also check all the the other connections at the same time.
Just throwing ideas up in the air mate!?
Reply to the thread, titled "powerflushing boilemate 2000" which is posted in Boiler Advice Forum on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
Boiler Advice Forum
Start date
Last reply date
Thread Tags
rosli2905,
Dannypipe,
